7 members (tclederman, Gdads51, 1955 1 Series, moparguy, Gray_Ghost, Otto Skorzeny, 1 invisible), 75 guests, and 10 robots.
Topics128,078
Posts1,056,027
Members48,433
#471562 11/15/2008 3:22 AM
I have bought several Carter 346 s carburetors and noticed a small difference in one.The bowl plunger shaft is flat on one instead of round.Anyone know why the different design or is that one not a 346 s ? Thank You in advance.
It's not the speed you travel it's the quality of the trip that matters !!!
backn37 #471605 11/15/2008 4:51 AM
Post a picture and you will probably get a better response. Just off hand I would guess that the one with the flat accelerator pump shaft might be a W1, model 684. Does it look like this one: http://rides.webshots.com/photo/2829647430098611668HBDljd
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Carburetion specialist
The flat accelerator pump was not used on the 346s. My guess would be either someone inadvertantly (or otherwise) switched a tag; or someone "married" the bowl cover and pump from a later carb to the 346s.
Jon.
The Carburetor Shop
carbking #471611 11/15/2008 5:11 AM
IT DOES NOT LOOK LIKE THE ONE IN THE LINK.NO CONNECTION TO THE THROTTLE AND CHOKE.IT DOES LOOK THE SAME AS A 346 THREE BENDS ON THE THROTTLE LINKAGE .IT DID NOT HAVE AN ID TAG ALL THOUGH OTHERS I HAVE DO.I HAVE PICTURES OF A 346 BUT IT DOESNT SHOW UNDER THE COVER.IF THE PLUNGER AND TOPS ARE INTERCHANGABLE THATS PROBABLY WHAT IS HAPPENING.THANKS
