5 members (DadsFirstPickup, 5 Window 9434, TUTS 59, Jon G, 1 invisible), 111 guests, and 1 robot.
Topics128,157
Posts1,056,874
Members48,456
Apprentice
Apprentice
I am installing a sbc/700r setup in my 56 TF. I have installed a 79 Firebird (Camaro) front clip and a 79 FB (Camaro) rear end. I am going to use the FB (Camaro) trans cross member.
I centered the trans tail shaft in the frame and bolted the cross member to the trans mount. I found the the cross member to be off center by almost a half inch. I then measured the pinion center line on the rear axle and discovered the pinion is also offset a half inch between the brake back plates.
What's going on here? Do I offset the tail shaft of the trans to match the rear end?
Offset or not, it makes no difference. (till you calculate total universal joint operating angle)
The most important part is having the centerline of both the transmission and the pinion be parallel.
Basically you put the engine wherever you want, but be sure the trans output shaft and the pinion are parallel
This tech tip has links to manuals that will explain it all in detail.
http://www.stovebolt.com/techtips/driveline/setup/index.html
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
Follow Grigg's advice, it will work just fine. U-joints need some angle to work right, ever look at a long straight truck or box truck? The driveline goes up and down at each joint.
If the transmission tail shaft is pointed down 3 degrees, the pinion should be pointing up 3 degrees, or close to it. Side to side as you have isn't much of a problem, its most likely only a degree or so off. Joe
