5 members (Rudedog53, Randy Baumann, Spikeytop, 50Chevy3100, Otto Skorzeny), 86 guests, and 6 robots.
Topics128,181
Posts1,057,191
Members48,465
#47109 07/01/2005 5:35 AM
Junior Member
Junior Member
I checked the numbers on the block of my truck's engine and found that it is a 1955-57 chevy 235. Does the engine from these years have solid or hydraulic lifters?
silver
#47110 07/01/2005 5:43 AM
Tab Offline
Solid. You should be able to hear them ticking. If you change them though you will have to change the cam too.
delete my account and pictures
#47111 07/01/2005 6:00 AM
Junior Member
Junior Member
Thanks, Tab. Do you know a good site for steps to adjusting the solid lifters on the 235 engine? Maybe mine don't need adjusting based on your comment. I do hear them ticking. Is that normal for the properly adjusted solid lifters?
Silver
#47112 07/01/2005 6:14 AM
Not necessarily true,Silver.
The 1957 235's matched with automatics were equipped with hydraulic lifters.
Man those boogers are expensive! smile
#47113 07/01/2005 6:15 AM
they should do a little clicking, if they don't they're too tight, but if they're pretty noisey you may have poor oiling to the top - if you don't have a shop manual, Kieth nicely put one online for us grin section 6page7
#47114 07/01/2005 1:26 PM
silver,
Here is a set of instructions for adjusting valve lash on 261/235/261 truck engines.
All 216/235/261 Chevrolet truck engines came with mechanical (solid) lifters (some of the later truck blocks were made to accept hydraulic lifters but they came with solid/mechanical lifters). As stated above, from 1954 onwards, the 235 Chevrolet automobile engine had hydraulic lifters (1953 PowerGlide engines did, too).
261 engines from Canadian Pontiacs had hydraulic lifters. I am not certain if later 235 truck engines with automatic transmissions came with hydraulic lifters (they did not in 1954/55).
Check out the Tech Tips section of this website (the link is also listed at the top of this page) for a lot of good information - look in the "Engine" section of Tech Tips for more instructions on setting valve lash.
Tim
#47115 07/03/2005 12:51 AM
1950-1951-1952 Passenger car 235 engines with PowerGlide transmission also had hydralic lifters
