6 members (JoergK., Guitplayer, Phak1, Bill Trotter, Southerntruck, Hotrod Lincoln), 100 guests, and 2 robots.
Topics128,195
Posts1,057,376
Members48,469
I only have one front fender with an area for the spare. Is that a 1/2 ton or were they on all fenders? Are they the same shape on a 1 1/2 ton as a 1/2 ton truck.
Thanks, While I own six cabs I only have one fender.
Troy
The key to flexibility is indecison!
I don't believe so, most Chevs use same cab, hood, grille but fenders get bigger along with the wheels.
Best of luck
1946 1/2-Ton Chevy
36 trucks had the spare mounted on the right front fender with a bar that was braced into the cowl and a piece from the bar that wrapped over the top of the tire. I believe JiMerit is correct about the size difference-- check in the photo gallery-- you might be able to see the difference.
Glenn
Apprentice
Apprentice
I have compared the 1936 1/2 ton and 1 1/2 ton fenders side by side, off the trucks, and I don't see any difference.
1936 Chevy 1/2 tons had the spare on the passenger side fender, GMC 1/2 tons had the spare on the drivers side. The larger trucks, Chevy and GMC, did not have fender mounted spares.
