9 members (Gdads51, jmoore, King Kielbasa, cmayna, 2-Ton, Danielbolt, JW51, Rusted Nut, 1 invisible), 86 guests, and 2 robots.
Topics128,169
Posts1,057,041
Members48,458
I used the search and found a lot of into on both the oil filter and clifford. I have the clifford intake and headers on order. I'm also interested in the beehive oil filter from patricks. The order description has an option for stock or Offy brackets. Will one of these work with a clifford intake?
[yrl=http://viewmorepics.myspace.com/index.cfm?fuseaction=user.viewPicture&friendID=43825635&albumId=1717519]More pictures in MySpace[/url]
This picture from Patrick's catalog shows a beehive on the other side away from the intake:
http://www.patricksantiquecars.com/chevyparts.htm
You'll have to invent your own way if you want it mounted to your intake.
You Tube
The beehive oil filter is mounted on the manifold side of Chevrolet 216/235/261 engines. My guess is that the engine at the Patrick's link (above) is a GMC straight-six (the oil filter on those engines is normally on the distributor side of the engine).
davidn,
Is it possible to mount a standard by-pass oil filter on the Clifford intake? If yes, the stock adapter from Patrick's should work. Note: call in your order and ask about the bracket you want - their old catalog had the parts numbers backwards.
Tim
