| | | Forums66 Topics128,021 Posts1,055,354 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2004 Posts: 196 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2004 Posts: 196 | wow my trucks finaly painted got the windowes in i was mounting the head lights and hooked up the battery to see if they worked all this smoke came pouring out of the dash turns out i had opened the windshield vent that hadent been open in years and the handle penched a wire going to the dash it looked really bad but only melted one wire lucky' the head lights work fine there was a broken spring on one the other had none. where dose the spring go this is on a 52 thanks for any help | | | | | Joined: Jun 2003 Posts: 565 'Bolter | | 'Bolter Joined: Jun 2003 Posts: 565 | nice to hear you got the paint on man thats scary about the wire glad nothin bad happened lucky thats all it was that must have freaked you out not sure about the spring cant tell by lookin at the other one?
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
| | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Aug 2004 Posts: 196 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2004 Posts: 196 | wow super 55 looks good it shows 4 spring but you realy cant see how they hook up my lights seem to be in pretty tight with out them it looks like they may go behind the bulb thanks for the help | | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | If I had my digital camera at home I could take a picture of mine for you. I'll be home late tonight, so I might not get a chance. Hopefully someone can help you until I can get a shot. A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | |
