0 members (),
297
Mod | | | Forums66 Topics128,162 Posts1,057,042 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#47011 06/29/2005 12:57 AM | | Anonymous Unregistered | | Anonymous Unregistered | The engine I've located does need a (partial) rebuild.
Heads are good, but the bottom end needs a rebuild.
Here's the plan to get some more juice. Bore out. New Pistons. Performance cam. Split Manifold and Dual Intake.
What is the biggest bore out it can get to(and still be stable)? I've heard 301 CI.
Any tips to squeeze out more juice?
Thanks for the sage advice. | | |
#47012 06/29/2005 1:01 AM | | Anonymous Unregistered | | Anonymous Unregistered | Oh yes. There is a second part:
I'm in the Los Angeles area. Any leads on a good machine shop that's familiar with the vintage inline 6's?
I'd have to get this puppy butchered. | | |
#47013 06/29/2005 4:06 AM | Joined: Nov 2004 Posts: 117 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2004 Posts: 117 | A few thoughts. Can be bored to .125 if lucky. Why not bore .060 and leave a little room for error and a future overhaul. If you are considering the dual carb Offy intake and Fenton header set up you will find there will be a lot of custom fitting of the intake required. (It took me about 4 hours of grinding, fitting, checking, grinding. Unless you are going racing the 261 truck cam has plenty of tourque. I replaced mine because of worn lobes. Good luck.
cgresham1212 If you don't drive it, why have it? 55 1st Series 3100 5 window
#47014 06/29/2005 4:23 AM | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | 40 Chev, man you guys in CA are lucky. There are lots of good Inliner shops out there.
Here's a few: Clifford Performance Temecula, CA 92592 909-303-2333
Ross Forged Pistons El Segundo, CA 310-536-0100 Sissell's Automotive Covina, CA 91723 626-331-2727 Cap's Hot Coatings Fresno, CA 93725 877-647-2628 That should get you started. Good luck. | | |
#47015 06/29/2005 5:07 AM | Joined: Nov 2004 Posts: 170 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2004 Posts: 170 | I wasn't going to mention my guy here in Temecula but since 53Moneypit mentioned Clifford Performance. I will say Dave Shaw at Arrow Engines. He just finished my 216. Great guy! You probably want someone a little more northern though. Good luck! P.S. Temecula is 951 area code. We just changed from 909. | | |
#47016 06/29/2005 5:42 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Boring more than 60 over is possible, but a sonic test must be done. Problem is mainly in the wall thickness to the water pump cavity. One improvement not mentioned is HEI. Also, get the head milled for more compression.
Fred 52 3600 69 C-10
#47017 06/29/2005 8:17 PM | Joined: Jan 2005 Posts: 279 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 279 | Becks Machine (805)925-7411 2240 rayville lane Santa Maria,Ca 93454
Gangster whites and straight pipes.....
#47018 06/29/2005 8:19 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Instead of boring the 261 way over, do a search on the Inliners.org site and order the back issue with the Caddilac 261. You can offset grind the stock crank and fit caddy pistons (and rods, I think) and make a 261 stroker with less piston and rod mass and keep the same rev range as the stock 261 with a heck of a lot more torque. Good 261 blocks are going to get more scarce and don't bore them any more than you have to.
