0 members (), 139 guests, and 7 robots.
Topics128,077
Posts1,056,033
Members48,433
#469592 11/09/2008 9:37 PM
Apprentice
Apprentice
I'm about ready to drop my newly overhauled 235 on to the frame of our 1950 AD. Do I need to have different motor mounts to support this 235 (taken out of a 1962 1/2 ton) or can I use the motor mounts used to support the 216 that was pulled out of the truck ?
Michael
MGrave50 #469639 11/10/2008 12:28 AM
The motor mounts on the 216 would have been the drilled front engine plate and the mounts off the bell housing. Are you using the same bell housing/trans combo? You can swap out the front plate or drill the 235 plate.
Drew
DrewP #469664 11/10/2008 1:49 AM
Apprentice
Apprentice
Drew,
I am using the same bell housing/trans combo. Are you saying I can use the two aft mounts but and then use a new front mount for the 235?
Michael
MGrave50 #469801 11/10/2008 12:06 PM
Yes. You can switch the front plate on the 216 to the 235 or just drill the 2 holes in the 235 front plate. It's been discussed in this forum if you care to search it.
Drew
DrewP #469802 11/10/2008 12:15 PM
Apprentice
Apprentice
Drew,
Thank you...I'll track it down
MGrave50 #469812 11/10/2008 1:35 PM
Actually,just go to the Tech Tips page and you'll find the info you need.
Drew
