| | | Forums66 Topics128,038 Posts1,055,585 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | I did all of my panel replacements with the cab mounted to the frame. It's the closest thing you have to a fixture. | | | | | Joined: Sep 2001 Posts: 272 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 272 | Czechman I can see the front & rear but the one that bolts to the frame??
Still Confused Brad
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | For the floor boards I ordered the floorboards that are made with HALF the toeboard....in one piece. The body man is working on it now. I'm not sure about pickups but on my 52 panel the front body mounts are welded to the bottom of the body right under the floorboard. I had to order two new ones and when we set the body back down on the chassis for final fit and tweaking I'll get all the others bolted in place, measure twice and then weld them to the bottom of the floorboard after snuging the new mounts to the chassis. Hope this helps you in some way. | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Replacing the front body mounts requires paying attention to a couple things. If you replace the floorboards be sure your floorboards are level so there is an even 1/4-inch gap between the mount and frame. THIS is what you want to avoid. I would suggest getting your frame up on jackstands and shimming under the stands until the frame is level left-to-right. Then when you install your floorboards be sure they are level and you are good. Also, temporarily fasten everything with #8 sheetmetal screws. It's a lot easier to unscrew something than it is to unweld something. To avoid removing too much sheetmetal I used the half floorboard patches and did one side at a time. It's not easy getting them in in halves and considering the amount of rot I had it would be a real chore wrestling a one-piece patch in there. If your cowls and sills are solid it might be easier. Good luck. | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | CzechmanI can see the front & rear but the one that bolts to the frame?? Oops... Mine is a '51. | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | If you are going to replace that much stuff you might consider finding another cab. I recently bought a 56 cab from Jimbo over at Cleburne for $600 that needs absolutely no repair except the usual back corners. If you replace that much stuff, you might wind up with a nightmare trying to get your alighnments right let alone the cash outlay. It's real easy to weld something like that together and discover you need custom made doors to fit in the hole. There are a couple of guys in Weatherford also that cut a lot of mid 50's trucks. | | |
