2 members (68ironhead, stlcardinalsguy), 187 guests, and 14 robots.
Topics128,078
Posts1,056,036
Members48,433
#46939 06/27/2005 1:07 PM
I am restoring a 54 GMC 1/2-ton Longbed PU and I am planning on installing power brakes with dual master cylinder. My truck currently has 4 wheel drum brakes and if I buy a power brake kit to work with my current setup, can I later upgrade my brake system to front disc brakes and still be able to use the same power brake system? I am asking since I see power brake systems for drum/drum, disc/drum, and disc/disc setups.
1954 GMC 1/2-ton Longbed
1971 Pontiac LeMans Sport
Yes, you can upgrade, usually just a master cylinder change or changing a residual valve.
Well I would not mind adding a residual valve, but I would rather not buy another master cylinder. If that is the case I might better bite the bullet and buy the front disc brake kit and power brake upgrade all at once. Anyone care to recommend a kit or vendor for this type of upgrade?
LT Offline
I bought a kit from Classic Performance Products (CPP)
www.classicperform.com
I asked the same question you have when I ordered the kit. The difference between drum/drum or disc/drum or disc/disc is the proportioning valve. In the CPP power booster kit, there is a proportioning valve attached to the master cylinder. When you want to convert to disc/drum, you swap in a new proportioning valve. The master cylinder and booster stay put.
#46943 06/28/2005 12:34 PM
LT, Did you go with the disc brake setup on your truck? If so, did you have any problem with the tires/wheel rubbing the calipers like they mention on the CPP site?
