3 members (2-Ton, carbking, Guitplayer), 291 guests, and 0 robots.
Topics128,089
Posts1,056,141
Members48,436
#469244 11/08/2008 7:35 PM
I bought a new wiring harness and started re-wiring my '49 Chevy 1/2-ton. It appears that full-load, unfused current is connected to one side of the ammeter. What prevents a short at this location through the gauge housing to ground? I see a thin paper insulator on the back of the housing. Is that it?? Seems like this set-up would be prone to a short. Are the lugs that penetrate through the housing supposed to be insulated so they don't contact the housing? Mine are not insulated. Again, it seems like a lug could easily contact the gauge housing and cause a direct short. Am I worried for nothing?
use a VOM & check for yourself
'''It appears that full-load, unfused current is connected to one side of the ammeter. '''''
that's one big reason why I am now using a volt meter and a three wire alt.
my.02
Jim & Caroline
my 2 cents is an ammeter is a short in the wiring.I have a volt meter also
Well if you search a bit for my recent experience with my new harness and ammeter here in Electrical........ I had a goofy thing happen with my new gauge. The long and short of it ( I could not resist that) is the meltdown of my starter to ammeter wire and it was smokey scary! I probably caused it with an unsecured speedo cable but you are right about the potential. I rewired and put a new ammeter in and finally got it right. However, I will have a battery disconnect for as long as this truck.
~ Rasman
1971 Chevy C10
"Old Yeller"
Saga: "'Old Yeller' ... More than a Pristine 1971 Chevy"
1959 Chevy 1/2-Ton
In the Legacy Gallery
