2 members (Bill Hanlon, 1 invisible), 62 guests, and 1 robot.
Topics128,049
Posts1,055,679
#469359 11/09/2008 2:55 AM
Me again. My 62 has been converted from the three on the tree to an sm420. I'm not sure how common it is, but it also has a 2 piece driveshaft. My problem is I am swapping in a T-5, and am not sure if I can run a 2-piece with the slip yoke. Also if anyone has installed a t-5 in a 60's swb, how long was the driveshaft? I have the original 3.90 rear end. Thanks
Who is John Galt?
Sounds like a unusual setup to me. If you wanna go to a one piece driveshaft,buy one from a wrecking yard that is too long. Then take it to a good machine shop and have it shortened and balanced. At the machine shop they should ba able,to tell you what measurement to take,so they can shorten it to the proper length.I went thru this when I converted my 55 from a four speed to a 700R4 automatic.Course my driveshaft was already too long as the 700R4 was longer than the 4 sp.
There's a good chance you can find one the right size at the salvage yard if you know how long it's needs to be.
ttodd #469629 11/10/2008 12:00 AM
Thanks for the replys! I've tried to guesstimate based on crude measurements, but it seems like a big margin of error. I will get the right number when the tranny is in.
Who is John Galt?
