| | | Forums66 Topics128,052 Posts1,055,727 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2008 Posts: 125 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 125 | Me again. My 62 has been converted from the three on the tree to an sm420. I'm not sure how common it is, but it also has a 2 piece driveshaft. My problem is I am swapping in a T-5, and am not sure if I can run a 2-piece with the slip yoke. Also if anyone has installed a t-5 in a 60's swb, how long was the driveshaft? I have the original 3.90 rear end. Thanks
Who is John Galt?
| | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | Sounds like a unusual setup to me. If you wanna go to a one piece driveshaft,buy one from a wrecking yard that is too long. Then take it to a good machine shop and have it shortened and balanced. At the machine shop they should ba able,to tell you what measurement to take,so they can shorten it to the proper length.I went thru this when I converted my 55 from a four speed to a 700R4 automatic.Course my driveshaft was already too long as the 700R4 was longer than the 4 sp. | | | | | Joined: Feb 2005 Posts: 469 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 469 | There's a good chance you can find one the right size at the salvage yard if you know how long it's needs to be. | | | | | Joined: Sep 2008 Posts: 125 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 125 | Thanks for the replys! I've tried to guesstimate based on crude measurements, but it seems like a big margin of error. I will get the right number when the tranny is in.
Who is John Galt?
