7 members (dt235sd, 3B, frogfarmer, 1955 1 Series, Bruce 1954-4100, DennisM, 1 invisible), 88 guests, and 1 robot.
Topics128,074
Posts1,055,910
Members48,429
#469255 11/08/2008 8:51 PM
1 Offline
I have Langdon's dual Carter Weber's on my '54 235 and I'm still having a little trouble with the electric chokes. I'm trying to determine if my chokes are working as advertised. I'm still having trouble with the engine dying about 30 seconds after sitting off for about 10 minutes. It seems as though it's starving for fuel. I have to pump the accelerator many times and let it cool a few minutes before it will start again. It's really got me confused.
Is the following logic correct?
I connected both chokes to a lead to my ignition. The chokes are normally "closed" and when the key is turned on, this heats a coil that opens the chokes as it heats?
I sure would like to have more control over the choke. Is there a way to convert to manual? Is there anything else that would cause this?
I have ruled out vapor lock as an issue.
The engine runs flawlessly otherwise.
Cory
1954 Chevy 3100
1952 Chevy Suburban
How are you "powering" the chokes?
1 Offline
I'm getting power off the ignition switch.
1954 Chevy 3100
1952 Chevy Suburban
Sorry about my stupid question.
Try pushing the gas pedal to the floor and releasing it. That will reset the choke flapper. Then, turn the key.
I have the same set-up on a 261 and the electric chokes have worked perfectly (hot or cold).
I also have the same set up on my 261. My chokes were acting crazy,basically they weren't working.I fused mine at the ignition switch.While testing and setting up,I blew the fuse,didn't realize it.I put a new 10 amp fuse in and she has been purring ever since.
Have you tried calling Tom Langdon and let him trouble shoot the problem ?
1951 3100 Chevrolet
