4 members (MickeyP, Lostbuthaulinass, Wally / Montana, 1 invisible), 122 guests, and 3 robots.
Topics128,050
Posts1,055,753
#469275 11/08/2008 9:50 PM
My front hub won't move but a 1/2" when I try to take it off the spindle. I'm positive that the brake shoe is a tight fit to the drum and the adjusters on the wheel cylinder appear to be rusted so I can't back them off.
I hate to spray anything near the shoes to loosen the adjusters. I've also tried prying with a screwdriver between the backing plate and drum. I also put the wheel back on and tried rocking that.
Can you unscrew the cylinder from the back and hope that falls down to loosens things up or would that really jamb things up? Any Ideas?
Kyle
1941 G506
More
1946 3800
Pic
More
1946 3600
Pic
More
1924 Ford Model T Fordor
Your shoes are already junk if they obsorbed enough moisture to rust to the drums. I would not worry about saving them.
OldSub #469322 11/09/2008 12:15 AM
if you got one try a hub puller. that always works for me
Well, prying and grunting didn't work so I loosened the cylinder bolts and slid it off the shoes. That worked great and the hub then slid right off. The shoes were in good shape as well as the drum. I think the wheel cylinder just put to much pressure on the brake pads, rusted, and wouldn't back off.
1941 G506
More
1946 3800
Pic
More
1946 3600
Pic
More
