1 members (Hotrod Lincoln),
72
0
Mod | | | Forums66 Topics128,049 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2006 Posts: 29 'Bolter | | 'Bolter Joined: Jan 2006 Posts: 29 | What are my options in adding a front clip to my 59? What models/years or cars or trucks should I be looking at? Thank you for your time | | | | | Joined: Feb 2007 Posts: 434 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 434 | To me what made the most sense was an aftermarket independent front suspension. Easier than putting a clip on in my opinion, and you end up with all new parts. Heidts, TCI, Fatman's, most of the larger hot rod suspension houses carry them.
R-Bo
1959 Apache 1/2 ton Big Window, Short bed Fleetside (under reconstruction) 1966 GMC 305V6 in the family
| | | | | Joined: Aug 2008 Posts: 230 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 230 | i used a 1974 suburban front frame clip it matched almost perfect, as is it will put you down in the weed's but i raised it up 4" to ride stock height ,still work in progress ,not done yet ,got it when i was 14 i am 49 now .my old man said if i got in a hurry it would cost me money !guess i took him to hart !  | | | | | Joined: Dec 2006 Posts: 7 New Guy | | New Guy Joined: Dec 2006 Posts: 7 | I used a 79 pontiac trans am under my 57.There is a very detailed post as to how to install a 70-81, second generation clip under these trucks. It really is pretty easy to do ,if your able to do basic welding, and will give you about a 7 inch drop.
Arch5807
