1 members (Guitplayer),
125
0
Mod | | | Forums66 Topics128,281 Posts1,058,486 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2008 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2008 Posts: 52 | Hello to all, I wanted my first post to be something usefull to someone, so here goes. I am in the process of doing the HEI distrubutor swap. Part of the modification involves filing off the hold down collar from the HEI dist. You can modify the original 235 hold down or come up with collar. A good source for the collar is McMaster-Carr. I found a two piece collar 1" diam. that fit the 250 dist perfectly. | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Thanks Chato for that piece of information and WELCOME to the forum. We are always looking for technical advice and parts info so we are really glad you've chosen us and hope you'll soon become a regular here. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I plan to attempt this conversion someday. What's the part # of that collar?
Thanks. | | | | | Joined: Aug 2008 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2008 Posts: 52 | The part number is 6436K73, this is for the aluminum 2 piece clamp on collar, descrption is as follows. 2 pc. clamp-on shaft collar 1" bore, 1-3/4 o.d. , 1/2 wide. Make sure you get the distributor hold down clamp from the donor 250 engine, it works well with this collar. | | | | | Joined: Jan 2007 Posts: 83 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 83 | Thanks Chato, That is the missing piece to my puzzle! Jason | | | | | Joined: Aug 2008 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2008 Posts: 52 | Thanks to everyone for the warm reception, Helipack I also have a 1954 3100, by the way another thing I found that made it easier for me to do this swap was to use a Dremmel with a cut off wheel to remove most of the 250 collar and then do the final filing by hand so not to over do it. Thanks again. | | | | | Joined: Jul 2006 Posts: 451 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 451 | nice little part. Always amazed at what McMaster has in stock. Welcome to the club. Cavebull | | | | | Joined: Aug 2008 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2008 Posts: 52 | There was something else that McmasterCarr was a good source for, the small screws on the thortle plate on my rochestor carb., I even was able to get a tap of that size from them, try to find that at home depot. Thanks again to all for the welcome. | | | | | Joined: Apr 2004 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2004 Posts: 72 | Just an FWIW for this thread. When I did my HEI conversion, I found my clamp at a Westlake Ace hardware store. It fit perfectly on the shaft of the ditributor. Also when i modified the distributor shaft, I used a lennth of all-thread (half inch I think)covered a section of it with black tape to protect the bushing insde the dist housing, then used some nuts to clamp it with. I then chucked it up in my drill press and used a grinder to work down the original hold down. Once close to size,I used a file and varying grits of sand paper to finish out the distributor shaft. This was before I got my lathe. Seems to work pretty good so far. I may have some pics if anyone is interested.
52 GMC Suburban...52 Chevy 3/4 ton...49 CHevy 1/2 ton Rod...49 GMC 1/2 ton retro rod project
| | | | | Joined: Aug 2004 Posts: 196 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2004 Posts: 196 | will a HEI work with a 6 volt system enyone try it to see if it would have spark | | | | | Joined: Feb 2004 Posts: 29,951 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,951 | Nope, not enough voltage to work the module, or the coil. It's strictly 12 volt only. Jerry
