2 members (Otto Skorzeny, KingG), 53 guests, and 2 robots.
Topics128,024
Posts1,055,390
Members48,422
#46896 06/27/2005 12:48 AM
Apprentice
Apprentice
54 has new cam and timing gear (its correct). Engine is timed, new battery, points, starter. Starts cold, runs fine, drags and does not want to start when first shut off. Will start 15 min. later. Any ideas HELP
#46897 06/27/2005 10:22 PM
Riding in the Passing Lane
I take it its still 6 volts. Use #1 gauge or larger battery cables. Run the ground to the engine or trans. Make shure all connections are clean & tight & lock washers where cable eyes hook up. Make shure there is a good ground cable between the engine & frame. smile
1972 Chevy c10 Cheyenne Super
#46898 06/27/2005 11:35 PM
I agree! With a 6 volt system the smaller size cables heat up and then have too much resistance.
Steve
#46899 06/28/2005 3:35 AM
I'll third those suggestions! Do some research and try for even 0 or 00 cables if possible. Tractor Supply has larger cables and ends, a welding supply can fab them also.
Another (more expensive) improvement is a 4-coil starter.
