2 members (baldeagle, CuzzFuzz),
27
0
Mod | | | Forums66 Topics128,003 Posts1,055,245 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#46814 06/24/2005 5:07 PM | Joined: Jan 2003 Posts: 24 Junior Member | | Junior Member Joined: Jan 2003 Posts: 24 | I have a '51 AD 3/4 ton with a new generator, new voltage regulator and a new battery (all 6 volt).
The problem is that the ammeter showed a good charge (about half way between 0 and full charge) up until a few days ago. For a while the ammeter showed that the system was discharging, but now the needle sits almost exactly at 0, showing a little bit of charging at higher RPMs and a little bit of discharging at idle. Turning on the headlights moves the needle to the discharge side.
What should the readings be? What might have happened? What can I do to get the system functioning properly?
Thanks in advance.
Rob | | |
#46815 06/25/2005 2:19 AM | Joined: Oct 2003 Posts: 124 Member | | Member Joined: Oct 2003 Posts: 124 | If your battery has a healthy charge, the ammeter will stay around zero. Drain the battery a bit and check - turn on your lights for a couple of minutes, then start her up. If you don't see a healthy charge with a little rev then you do have a problem.
A poor battery terminal conection can cause this symptom - happened to me a few weeks ago.
If that's not it - the recent changes you made are probably it.
The service manual describes how to check the charging system with a meter, that's the quickest time to run down the problem. | | |
#46816 06/25/2005 3:08 AM | Joined: Jul 2003 Posts: 586 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 586 | It all sounds normal to me. Once your battery got up to a full 6V charge, it's not going to charge anymore. Thats why your neetle reads zero. Turning on the headlights will discharge your battery a little. It's also normal to see the neetle go negative when the truck is at idle, especially with the lights on. Cecil..... | | |
