Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
2 members (GMCJammer51, baldeagle), 43 guests, and 3 robots.
Topics128,004
Posts1,055,246
Members48,418
#46814 06/24/2005 5:07 PM
Junior Member
Junior Member
I have a '51 AD 3/4 ton with a new generator, new voltage regulator and a new battery (all 6 volt).
The problem is that the ammeter showed a good charge (about half way between 0 and full charge) up until a few days ago. For a while the ammeter showed that the system was discharging, but now the needle sits almost exactly at 0, showing a little bit of charging at higher RPMs and a little bit of discharging at idle. Turning on the headlights moves the needle to the discharge side.
What should the readings be? What might have happened? What can I do to get the system functioning properly?
Thanks in advance.
Rob
#46815 06/25/2005 2:19 AM
If your battery has a healthy charge, the ammeter will stay around zero. Drain the battery a bit and check - turn on your lights for a couple of minutes, then start her up. If you don't see a healthy charge with a little rev then you do have a problem.
A poor battery terminal conection can cause this symptom - happened to me a few weeks ago.
If that's not it - the recent changes you made are probably it.
The service manual describes how to check the charging system with a meter, that's the quickest time to run down the problem.
#46816 06/25/2005 3:08 AM
It all sounds normal to me. Once your battery got up to a full 6V charge, it's not going to charge anymore. Thats why your neetle reads zero. Turning on the headlights will discharge your battery a little. It's also normal to see the neetle go negative when the truck is at idle, especially with the lights on. Cecil.....
