2 members (baldeagle, 78buckshot), 79 guests, and 5 robots.
Topics128,014
Posts1,055,327
Members48,419
#46794 06/24/2005 2:21 AM
Junior Member
Junior Member
Having problems with wire that comes from the alternator to the ignition switch, the wire touched the manifold and burned up. Replace with new wire and replaced with new ignition switch. I have checked all wires to make sure that there are no melted wires. You turn the truck on alternator works and runs fine but it will not turn the truck off when you turn the key. If you take the wire off the ignition swithch to the altenator it will shut off. Do you think the alternator is backing feeding through the wire? Is wire from ignition switch feeding the alternator?
I've never been lost just confused for a month or two. 1950 & 1952 chev. 1998 Chev 4x4.
#46795 06/24/2005 2:30 AM
There is a diaode in the wire, probably near the alternator, that keeps the flow from coming back through. Look for a slight bump in the wire. Don't know if it's still good or not. Try rewiring it in and see what happens. Hopefully you didn't throw the old one away yet. If ya did, Patricks has em for ya.
#46796 06/24/2005 2:37 AM
Junior Member
Junior Member
Thanks is that what that little melted piece of plastic was?
#46797 06/24/2005 2:50 AM
My best guess is prolly. grin
