| | | Forums66 Topics128,284 Posts1,058,526 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#46784 06/23/2005 9:30 PM | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | Hey guys, Does anyone out there know what the gear ratio would be in a 62 GMC 1/2 ton 4x4? This is a parts truck and I am considering using the transfer case and axles to convert my 52 3/4 ton to 4 wheel drive. Thanks for any help | | |
#46785 06/23/2005 10:16 PM | Joined: Dec 2001 Posts: 215 Shop Shark | | Shop Shark Joined: Dec 2001 Posts: 215 | 4.11 or 4.56 cant remember wich one was standerd but think it was 4.11 on the 1/2 tons those axles will be a hare wide but if you use offset wheels it should look pretty good | | |
#46786 06/24/2005 2:08 AM | Joined: Dec 2004 Posts: 452 Member | | Member Joined: Dec 2004 Posts: 452 | It appears the '62 GMC 4x4 (K-1000) used a 3.92 ratio. Check this page.
Curt ---- 1953 Chevy 6400, 1957 Chevy 2dr Sedan --"Mediocrity is easy, the good things take time"
#46787 06/24/2005 9:05 PM | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | Thanks for the info...that page has some great information. As far as width, the rear axle on the GMC is slightly narrower than my stock 3/4 ton rear measuring to the outside of the tires. Haven't checked the front axle width yet. | | |
#46788 06/28/2005 9:36 PM | Joined: Feb 2005 Posts: 81 Member | | Member Joined: Feb 2005 Posts: 81 | outside of tire measurements are potentially misleading. the 4x4 boards i'm on use wms-wms numbers, which eliminates the offset and width of the wheel. wms = wheel mounting surface
i've kicked around taking axles from a more modern 4x4 to convert my 52 3/4 ton too, and one of the issues is spring perch width. the frame on the AD is different width than the donor axles, and the donors are wider overall.
something else to consider is the end use of the truck. if you want to go wheeling, the travel before hitting the bump stops is pretty small. for just tooling around and the odd fire road it won't be an issue. | | |
