Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (red450IH, Tronman, oldsteve), 166 guests, and 3 robots.
Topics128,289
Posts1,058,583
Members48,492
#46777 06/23/2005 5:33 PM
Do you have a fanshroud on your stovebolt? If so, where did you get it or how did you make it? What materials did you use?
How did all this sawdust get under the hood?
ttt
Perhaps you could make one out of sheet metal? I made one earlier this year for my '54 Pontiac out of 20 gauge steel. Turned out pretty good. Along with a new fan, it created a nice draw across the radiator.
What's this for anyhow?
-David
Tradin' up dimes for nickels...
My \'65 Chevy C-20
Cut a piece of cardboard to fit radiator space, cut out the fan area, take this piece of cardboard to the bone yard and walk around comparing it to the fanshrouds to find exactly which one you want.
Then, be a good sport, and post the year make and model of the car you pulled it from!
