8 members (55shaker, RoadsScholar, warlock, 5 Window 9434, Otto Skorzeny, k2handyman, 6inarow, 1 invisible), 85 guests, and 2 robots.
Topics128,048
Posts1,055,626
#46752 06/23/2005 1:24 AM
Junior Member
Junior Member
What is the operating temperature of a GM 216 engine? I just finished rebuilding this engine and it is running around 200, is this normal?
It'll probably run a bit hot until the rings seat in. Double check the timing, valve adjust etc. Also, dont run straight coolant, just enough to prevent corrosion. Straight water will cool better than coolant. Also, your temp gauge may be off as well, don't forget to run a thermostat.
1946 1/2-Ton Chevy
According to the guage in my '50, it runs about 170-175 with a 160 thermostat. Doesn't matter how hot or cold outside, always within a coupe of degrees of that. Also has the stock radiator cap, which is non-pressurized.
I would think that 200 is hotter than normal. If you have a thermostat, try running without it as a test.
1951 1 Ton Completed
My 216 last summer in Misery heat ran an indicated 190-200 on the guage all the time. Numerous checks with thermoter in radiater said 180. 180 thermostat, pickup for the capilary tube is close to the head and I assume it is a little hotter there. Ck and see what your true water temp is. I had reversed flushed the entire cooling system and radiator twice. Truck never boiled over. I bottle of water wetter will lower you temp about 5-7 degress also.
