9 members (warlock, mick53, 55shaker, fonz8261, Ponchogl, RoadsScholar, Gdads51, Otto Skorzeny, 32Fordpuchoptop),
105
Mod | | | Forums66 Topics128,048 Posts1,055,626 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#46752 06/23/2005 1:24 AM | Joined: Jun 2005 Posts: 1 Junior Member | | Junior Member Joined: Jun 2005 Posts: 1 | What is the operating temperature of a GM 216 engine? I just finished rebuilding this engine and it is running around 200, is this normal?
Thanks | | |
#46753 06/23/2005 1:50 AM | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | It'll probably run a bit hot until the rings seat in. Double check the timing, valve adjust etc. Also, dont run straight coolant, just enough to prevent corrosion. Straight water will cool better than coolant. Also, your temp gauge may be off as well, don't forget to run a thermostat. | | |
#46754 06/23/2005 2:17 PM | Joined: Jan 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 428 | According to the guage in my '50, it runs about 170-175 with a 160 thermostat. Doesn't matter how hot or cold outside, always within a coupe of degrees of that. Also has the stock radiator cap, which is non-pressurized. | | |
#46755 06/23/2005 7:40 PM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I would think that 200 is hotter than normal. If you have a thermostat, try running without it as a test. | | |
#46756 06/24/2005 2:36 PM | Joined: Jul 2002 Posts: 188 Member | | Member Joined: Jul 2002 Posts: 188 | My 216 last summer in Misery heat ran an indicated 190-200 on the guage all the time. Numerous checks with thermoter in radiater said 180. 180 thermostat, pickup for the capilary tube is close to the head and I assume it is a little hotter there. Ck and see what your true water temp is. I had reversed flushed the entire cooling system and radiator twice. Truck never boiled over. I bottle of water wetter will lower you temp about 5-7 degress also. | | |
