7 members (J Lucas, Otto Skorzeny, Chuck52, TooMany2count, Gray_Ghost, Sjm, 1 invisible),
74
Mod | | | Forums66 Topics128,259 Posts1,058,305 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 293 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2007 Posts: 293 | I've read the threads on sway bars. Most say they significantly improve handling. However, I'd like to keep my '49 1/2-ton stock. Were front and rear sway bars available as original equipment? My shop manual makes reference to a front sway bar, so I'm thinking they were original. What about the rear? Do after market shops sell sway bars that do the trick? Any recommendations? | | | | | Joined: Jan 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 428 | Front sway bars were original equipment on AD suburbans. I installed an original on my stock '50 pickup and I did notice an improvement in cornering as there was quite a bit less body roll. I'm running old bias ply 6:00-16 tires up front so it's not headed for the slalom course, but I was happy with the improvement. Probably have about $50 wrapped up into it total with what I gave for the bar and brackets at a swap meet plus new bushings from one of the suppliers.
Bob | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | As stated above, the stabilizer assembly (anti-sway bar) was standard equipment on panel-body Advance-Design trucks from 47-55. Although, for some years it is not listed for Canopy Express. There were two styles of assemblies and Jim Carter sells sets of rubber bushings for both both styles of assemblies (and he sometimes has used assemblies for sale). The original assembles will bolt right up to any A-D 1/2 ton (and, maybe 3/4 ton) front-ends. Jim Carter and others also sell after market anti-sway bars. | | |
