6 members (37 GC, klhansen, Shade Baby, Reftys49, MaxStewart, Philipj), 95 guests, and 1 robot.
Topics128,143
Posts1,056,786
Members48,454
#466745 10/31/2008 12:35 PM
I did a compression test on the 216 in my 52. I had low readings on the dry test. On the wet test the readings were even lower. Yes the procedure was the same on both tests, to include the amount of oil I squirted in, the same number of cranks, evrything. Cylinders 1 and 6 had the highest readings, 90-95 wet, possible warped head?? But, no contamination of anti freez or oil.
I think it may be time for a different engine.
1946 1-ton Panel
1952 1-ton Comml. W/Grain Body
Was the engine cranking at the same speed?just a thought...Tom
Yes, three surges each time. This is a 6V system.
1946 1-ton Panel
Sounds like your compression guage is getting some oil in it making the readings inaccurate,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
Thanks Scott,
That makes sense and I will do another test. I did use more oil than I usually do, just to make sure to rings were sealed.
Mike
1946 1-ton Panel
I agree with the gauge being the trouble. There is a check valve somewhere in the gauge, usually at the cylinder end of the hose or fitting- depending on what kind of gauge you have. If the check valve is sticking, you will have low compression readings. Your pressures are pretty low for a wet check.
Have you used that compression gauge on other engines, and found better/higher pressures? If not, the check valve in your gauge may have been replaced with a tire valve, which will/may cause lower compression readings because tire valves have stiffer springs. A stiff spring means delayed opening under pressure and early closing as the pressure nears the peak- result- a lower pressure reading. Most compression gauges have very weak check valve springs.
Harvester
Harvester;
I have used it and had higher numbers.I bought this new and have only used a few times. I will lookit over and do the test again this weekend.
Mike
1946 1-ton Panel
OK; I borrowed another gauge and tried again. This time no pressure in any cylinder. All the plugs were out. It would show compression but leak down immediately. I am going to try a running compression test tomorrow.
This engine will still run, no fluid contamination, no leaks, no blow by, no smoke.
1946 1-ton Panel
Lets see you have no compression and the engine runs. Call GM R&D you have a new type of engine.
Just kidding, I think you have another bad gauge.
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson"
The Shrader valve on the tester is stuck. Time for another one,
Scott
Scott Ward
1 1950 3100
1 1955.1 Chevy 6500
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
How is the engine running? Why are you testing?
~Jim
I've never run the motor when cheching comp,I knew a guy that did it all the time,his comp gadges only lasted about 2 months.He said that that's how they are supposed to work!I'd go for the schrader valve,I've had em go bad for me.Got spare's from the snap on truck,not to expensive either.Tom
