2 members (moparguy, Gray_Ghost), 109 guests, and 0 robots.
Topics128,048
Posts1,055,540
Members48,425
#465736 10/28/2008 8:05 PM
ccb
Offline
Apprentice
Apprentice
has anybody ever used a stitch welder from eastwood or something similar? it hooks up to an arc welder. for patch panels. ccb
ccb #467016 11/01/2008 5:01 AM
Sorry, I never have. I figured my money was better spent on a MIG welder.
I figured I would try to respond to let you know that I did read your post and give you my 2 cents worth..
God bless..
Jesus is Lord!
Only through the blood of Jesus are you washed clean of your sins.
Come see us... Dad's Chevy
Our Video
God bless you! Michael..
Michael1964 #467051 11/01/2008 10:48 AM
I agree with Michael1964 that your money would be better spent on a Mig Unit such as a Miller, Lincoin or a Hobart unit in the 125 to 140 Amp. range. I also would prefer the 240 volt units. When using a Mig unit there is zero slag problems to deal with if you use shielding gas instead of flux core wire. Much nicer looking welds. You can stitch weld your material to lessen the heat and warping problems. Be sure to spot weld your material together first. Stitch welding is a form of welding a piece of material in different spots to keep the heat from warping the material with solid welding bead. The use of Copper backup bars to keep from burning through along with a product called Heet Fence placed along the side of the edges to be welded approxmately 1/4" away to keep the heat from warping your weld area is highly recomended.
62Blue
Don
62Blue
62Chevy in progress
You've never been lost until you've been lost at Mach3" Paul F Crichmore (Test Pilot)
Don G. #467114 11/01/2008 7:20 PM
ccb
Offline
Apprentice
Apprentice
thanks for the input, i think santa may bring a hobart 140 this year. i just ran across the stitch welder on eastman's web site. i could not find much about them, probably a good reason. ccb
