0 members (),
108
Mod | | | Forums66 Topics128,035 Posts1,055,560 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2008 Posts: 26 Apprentice | | Apprentice Joined: Oct 2008 Posts: 26 | has anybody ever used a stitch welder from eastwood or something similar? it hooks up to an arc welder. for patch panels. ccb
| | | | | Joined: Aug 2006 Posts: 237 Shop Shark | | Shop Shark Joined: Aug 2006 Posts: 237 | Sorry, I never have. I figured my money was better spent on a MIG welder.
I figured I would try to respond to let you know that I did read your post and give you my 2 cents worth..
God bless..
Jesus is Lord! Only through the blood of Jesus are you washed clean of your sins. Come see us... Dad's Chevy Our VideoGod bless you! Michael..
| | | | | Joined: Aug 2008 Posts: 403 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 403 | I agree with Michael1964 that your money would be better spent on a Mig Unit such as a Miller, Lincoin or a Hobart unit in the 125 to 140 Amp. range. I also would prefer the 240 volt units. When using a Mig unit there is zero slag problems to deal with if you use shielding gas instead of flux core wire. Much nicer looking welds. You can stitch weld your material to lessen the heat and warping problems. Be sure to spot weld your material together first. Stitch welding is a form of welding a piece of material in different spots to keep the heat from warping the material with solid welding bead. The use of Copper backup bars to keep from burning through along with a product called Heet Fence placed along the side of the edges to be welded approxmately 1/4" away to keep the heat from warping your weld area is highly recomended. 62Blue Don
62Blue 62Chevy in progress You've never been lost until you've been lost at Mach3" Paul F Crichmore (Test Pilot)
| | | | | Joined: Oct 2008 Posts: 26 Apprentice | | Apprentice Joined: Oct 2008 Posts: 26 | thanks for the input, i think santa may bring a hobart 140 this year. i just ran across the stitch welder on eastman's web site. i could not find much about them, probably a good reason. ccb | | |
