3 members (55shaker, Phak1, dt235sd), 90 guests, and 2 robots.
Topics128,094
Posts1,056,483
Members48,444
#467045 11/01/2008 7:55 AM
1 Offline
guys has anyone here done this? looking to end up with 5 on 5" bolt circle like 73'-87' chevy truck. most people want to change to 5on4.75" or 5on 4.5" bolt circle. guess it would be same as caddy,full size gm car also. thanks
I haven't done any but I have seen them installed and they work fine. Most of the aftermarket suppliers can provide just about anything lately. My 88 has the 5 on 5 bolt pattern and it was used up through 98 on the 1500 series 2 wheel drive. That will give you more options for a rear end. I don't know if the width is compatable with a TF truck though.
Fred
yes, i have done the conversion, but with the 5 on 4.750 bolt circle. mine is a 57 3100 with straight axle front.
i think with the 4.750 bolt circle you will have more wheel options.
leonard
1957 Chevy 3100 1/2-Ton
Photobucket pictures
1 Offline
i have the brackets for the 4.75 disc conversion but that won't match the rear end.
yes, i hear you.
i had to buy a cragar ss wheel that had dual bolt pattern to carry as a spare, to get around that issue.
good luck.
leonard
