8 members (TUTS 59, 55shaker, moparguy, KEVINSKI, Otto Skorzeny, Lostbuthaulinass, 32Fordpuchoptop, 1 invisible),
103
Mod | | | Forums66 Topics128,141 Posts1,056,487 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 595 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 595 | guys has anyone here done this? looking to end up with 5 on 5" bolt circle like 73'-87' chevy truck. most people want to change to 5on4.75" or 5on 4.5" bolt circle. guess it would be same as caddy,full size gm car also. thanks | | | | | Joined: Apr 2005 Posts: 2,098 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,098 | I haven't done any but I have seen them installed and they work fine. Most of the aftermarket suppliers can provide just about anything lately. My 88 has the 5 on 5 bolt pattern and it was used up through 98 on the 1500 series 2 wheel drive. That will give you more options for a rear end. I don't know if the width is compatable with a TF truck though. Fred
| | | | | Joined: Aug 2007 Posts: 1,082 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 1,082 | yes, i have done the conversion, but with the 5 on 4.750 bolt circle. mine is a 57 3100 with straight axle front. i think with the 4.750 bolt circle you will have more wheel options.
leonard | | | | | Joined: Jul 2005 Posts: 595 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 595 | i have the brackets for the 4.75 disc conversion but that won't match the rear end. | | | | | Joined: Aug 2007 Posts: 1,082 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 1,082 | yes, i hear you. i had to buy a cragar ss wheel that had dual bolt pattern to carry as a spare, to get around that issue. good luck.
leonard | | |
