Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (UnclePaddy, Peggy M, Oswald), 105 guests, and 3 robots.
Topics128,281
Posts1,058,460
Members48,490
#466399 10/30/2008 4:32 PM
I used the search feature and found that I need a sway bar from a '89 Camaro IROC Z28 to install on my '51.
Can/will someone please tell me what the diameter of the rod is? I have someone that has a sway bar but he's not sure it is the correct one.
Thanks in advance for your help and information.
Thruwurkin
Half Ton Will Travel
God bless America...One nation under God
31mm (1.220")front / 21mm (0.827")rear
Bluedawg
God fearing, Gun toting, Constitution loving extremist.
Thank you for the info.
Thruwurkin
The IROC-Z bar mounts on the bottom of the Camaro differential using a U-bolt clamp. The clamp has a notch in it which fits over a tab welded on the bottom of the axle tube. This is to prevent the clamp assembly from moving around the axle tube.
When you go to mount your bar on your truck, you'll find that it will need to go on TOP of the axle tube. This lets you use the stock control links. You may have to use a 3" U-bolt as the Camaro axle tubes are only 2-5/8" in diameter. By mounting the the bar on the top of the diff, you'll be able to drill one hole in each lower frame rail and keep your control links vertical with weight on the diff. I just made a small tack weld on the mount bracket-to-axle tube to insure it won't try to rotate.
The eye-to-eye measurement on the "Z" bar is 39" which almost centers the link-to-frame hole in the center of the bottom section of the frame rail.
You'll find that the heavier "Z" bar, combined with an aftermarket front bar, will all but eliminate body roll. The sway bar addition was probably the most dynamic modification you'll make to your suspension. This combined with a good set of gas shocks and radial tires, will transform your truck into a great driving road machine.
Dave
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
Thanks for this info. It should truly be a "Tech Tip". I found the threads about what to use but had no idea about the little details you gave.
I have the front sway bar installed on my '51 and it made all the difference in the world. I have 3.55 gears in it and run 60mph, pulling a Teardrop trailer. At that speed, with the TD behind, it still tends to roll a little on faster than normal lane changes. I'm hoping to eliminate that with the rear sway bar.
Again, thanks to all that responded and to those that even read the post.
Thruwurkiin
