Try looking it up under dow corning products, I think called graphoil- generally used in high temperature valve packing seals, which are very similar to the rear main seal in a 216 engine. If Dow corning does not have it, Look for your local swagelok dealer and tell them you need to get some graphoil lubricant, they will have to do a tech service request to the factory to get it, and it will take an extra week, but they can get their hands on it.
www.swagelok.comThey might be able to get it in little one time use tubes where you tear off the end.
It is good stuff
If that does not work, my local refinery(That I work with) used pure nickel special for gasket dressing, pure nickel special is the product name. It is an anti seize
I have personally used Loctite nickel anti seize in the same manner with success, I use it to dress head gaskets, exhaust gaskets, as well as the bolts and such-
I kind of ramble a lot, but I hope this helps
