7 members (55shaker, TexasA&M48Truck, MickeyP, Ponchogl, Hotrod Lincoln, Nick in Manitou, 1 invisible), 126 guests, and 3 robots.
Topics128,026
Posts1,055,406
Members48,422
#465726 10/28/2008 7:09 PM
1 Offline
I have a 1968 250 CI. Just fit on the new compression rings and got the pistons back on the crankshaft. Can any one give me torque specs and patterns for my head bolts, and do you know if the nuts for my piston rod bearings have to be torqued? Also, we had to take off the intake/exhaust manifold, so i had to take off the carb with it. I had to undo some wires and springs, if i put them back in the same place, will my floats get messed up or anything?
3 Speed Or No Speed
1965 Chevrolet C10 Stepside
head bolts 95 rods 35 mains 65 ,i e-mailed a picture of tightening sequence for cylinder head .you should not have a problem with the carburetor
you prob already know this but it's a good idea to tighten each rod nut alternating side to side and increasing every 10 lbs till you get up to final torqe. are you changing the rod bearings as well? the manifolds are suposed to be torqed as well and the outside two are a little less. good luck
1 Offline
I guess that's what they're called. 2 semi-circle sheets of metal on the bottom of the piston that rotate around the crankshaft. They're bearing of some sort, but im not sure which, and yes i replaced them. A lot of people said it was my carburetor causing the problem (had gas in my oil pan, truck was diesling after i shut it off and it smelled like gas really bad), but when about one cup's worth of antifreeze got into my rear cylinder when i pulled the head off...and it had seeped past the piston after 5 minutes, we figured i was due for a ring job. You think that's sufficient evidence?
And by the way old dog, got your e-mail and the pic. I can see it fine, really do appreciate it man. Do you think you could find the same specs for the manifolds? Thanks again
3 Speed Or No Speed
1965 Chevy c 10,
While you have it apart DOUBLE check the fuel pump. a leaking diaphram will also put gas into oil - been there
Brad
if you can get a torque wrench on the outer 20 ft pounds other's 30 .i just used a wrench buy hand or ratchet .
