4 members (Hotrod Lincoln, Guitplayer, LAROKE, 1 invisible), 54 guests, and 3 robots.
Topics128,154
Posts1,056,840
Members48,456
#464486 10/24/2008 4:40 AM
I have an old aftermarket turn signal unit that I restored and would like to get everything hocked up and wired properly this winter so that I have turn signals next year. Anybody out there have some good wiring instructions that I would be able to get a copy of as a reference. While I'm pretty sure I could figure this one out if I thought about it hard enough; I'm reluctant to think that hard if someone already has it written down somewhere.
If you do, I promise that I will take a ton of photos and publish a page documenting the job for everybody in the future not wanting to think that hard as well.
Tim
Tim Sheridan
1947 First Series Chevy 1/2-Ton
"Liberty Series" - "Art Deco" - Whatever you'd like to call it.
Tim,
I don't know what kind of device you have but I have linked a site that has some good diagrams for Signal-Stat units. There is also a good article by Cletis in the Tech-Tip section. Good luck.
http://www.film.queensu.ca/CJ3B/Tech/SignalWiring.html
Stuart
simply power from battery to a fused source. fused source to flasher unit. flasher unit to ''IN'' of a turn signal unit. out of the turn signal unit to L/R/F/B.
yes there is lots more about flasher units. some have a 4 way 'emer' switch. some 4 ways don't need to be on the 'IGN' side of a circuit. i think stu's diagram covers it in more detail.
you can wire up turn cab indicator lamps @ the 'out-put wire.
NOTE:: if you use LED's they need to have some resistance to them. It drove me crazy for about 30 minutes because i did not have me front lamps connected when testing me system. that's where i have me ''regular'' incandescent bulbs that create the resistance i needed to make the flasher unit work. dang
Jim & Caroline
Tim:
There are several different types of after market units. The one that I rebuilt is not a self canceling unit. It has two small pilot lights on the switch unit that flash with the turn signals to let you know the turn signals are on and also to let you know that the main lamps are not burned out. If yours is like this I have a rough diagram of how it is wired.
1941 Chevy Master 3/4-Ton
More images in the Bolt Bucket
Born to fish, the truck is only a hobby.
Mine is a signal stat 700 very early model that may be like yours. Your description is right on.
Tim
Tim Sheridan
Exactly like mine, I also have a Signal-Stat 700 !!!
Sent you an email, photos are easer that way, at least for me they are.
