4 members (tclederman, FAST55, JW51, 1 invisible), 88 guests, and 3 robots.
Topics128,269
Posts1,058,398
Members48,485
#464361 10/23/2008 8:40 PM
Most of the after market companys sell oil pressure rubber lines(grease gun line) that goes from the oil filter to the motor. The openings are very small on the lines. If i make up some larger diameter lines, will this cause the oil pressure to drop dangerously low? Bigger lines with more flow will filter the oil better, but not at the expense of the engine. Cecil............
Riding in the Passing Lane
It will lower the oil pressure. The regular lines work fine. These are bypass filters. All the oil eventually goes through it.
1972 Chevy c10 Cheyenne Super
