6 members (Tronman, wilbur53, Jon G, GMCJammer51, Hotrod Lincoln, 1 invisible), 85 guests, and 2 robots.
Topics128,109
Posts1,056,569
Members48,448
i guess after several conversations with people on here I am re thinking the plan of attack for my 48 chevy half ton and am going to consider the chasis engineering bolt on mustang 2 suspension. I need to decide if I am going to use the stock mustang 2 spindles or go with the 2 inch dropped units. If anyone has used the kit or can provide any info it will greatly be appreciated.
I used the TCI setup and prefer the welded in unit,however thats personal preference. As far as the dropped spindles ,it all depends on what you want the end result to be.I used dropped spindles and I like the lowered frontend. I also used a TCI kit to lower the rearend,but then again thats personal preference.If you want to maintain the stock look ,go with the regular spindles.
Apprentice
Apprentice
I used a TCI Must II IFS w/dropped spindles. It sat too low.
I now use stock spindles with 1/2 a coil cut.
Don
Don Meyer - Mech Engr(retired)
48 GMV
66 RR
64 Corvair
Apprentice
Apprentice
Don
48 GMV
66 RR
64 Corvair
