3 members (Bill Hanlon, Hanks custodian, Nick in Manitou), 75 guests, and 3 robots.
Topics128,080
Posts1,055,953
Members48,430
#462613 10/18/2008 3:03 AM
Took my panel apart today to clean it and found the clear plastic face has an old decal applied in the spot for the tach ( not equipped on my truck )
The decal is a mylar type material about an 1 1/2" square.One corner was away from the cover so I tried to peel it back and the corner snapped off . Being very old, it is brittle. What is a good way to remove it it? Didn't want to use a chemical that would possibly eat into the plastic. Any ideas?????
My truck is a 1968 C10
Is your clear plastic yellowed or scratched? If it is not, wait for a better reply. If it is I would gently try to scrape it off. Then using a sanding paper (depending on scratches, yellowing or cloudiness) use anywhere from a 400 grit max (your particular problem would dictate what grit to start with) up to a 12,000 grit sand paper (Micro-mesh kit for plastic refinishing can be found on-line) and with a little elbow grease you should end up with a pristine finish.
1937 Chevy 1/2-Ton
The plastic is in good shape, not cracked crazed or yellow.There must be a way. I did check online there are lots of fix and cures?
I will check a plastics store first hope they can guide me.
