3 members (MRMEROTH11, Charles in CA, mick53), 150 guests, and 1 robot.
Topics128,113
Posts1,056,279
Members48,439
#46235 06/13/2005 5:10 AM
Hi...i have a 49 GMC,,,runs like a tractor,,my brother..moved it a little bit..Bang!!..blew muffler out..I tried to start it,,but she just won't pop..A freind of mine said,,probably cracked a Distributer..Does the GMC share the same kind of Distributer as the Chevy( i have some of those)... eek
#46236 06/13/2005 5:44 AM
Tab Offline
If it blew the muffler out, it backfired through the exhaust. This generally doesn't cause internal engine damage.
delete my account and pictures
#46237 06/13/2005 6:36 AM
Distributor's the same, but I'm thinking they have different vacuum advance.
Lots of things could be wrong. Start by checking the firing order. 153624. Then move to the points, spark plugs. It is possible to have a cracked distributor cap, but that usually won't keep one from starting.
Fred
52 3600
69 C-10
#46238 06/14/2005 9:50 AM
I'm thinking whatever made it backfire is why it won't start. I wonder if it might have gotten a load of gas in the exhaust manifold from a stuck float,and when it started,it ignited in the exhaust pipe and blew up the muffler. with a stuck float it might have drowned the plugs.
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
#46239 06/14/2005 10:44 AM
i just had to replage my float it was cracked skake and see you can get a new float for 10.00
#46240 06/16/2005 10:55 AM
V
V Offline
Start by checking firing order/ignition timing then check the distributor cap and rotor for cracks.Pull the spark plugs and see if they look wet if so you might have excess fuel going into the engine (flooding)i would check the timing/firing order first also check for proper point gap setting.
#46241 06/16/2005 2:39 PM
U
U Offline
Check the coil. I've had this happen 4 or 5 times.(I'm just lucky I guess) One time I blew up a muffler on my '62 Impala. Man, sounded like a shotgun went off underneath me! It was the coil. Coil dies. Fuel loads up & then combusts. Put on new coil & starts up no problem. Good luck.
Life is good. Keep on playing.
#46242 06/17/2005 12:58 AM
Timing chain could have jumped a tooth, causing the misfire that blew out your muffler.now because of the cain being in the wrong tooth, your timing is out and it won't start. That's my guess.
#46243 06/17/2005 1:56 AM
Junior Member
Junior Member
:rolleyes: does a49 gmc have timeing chain???
#46244 06/17/2005 7:39 PM
No timing chain in a Jimmy.
Replace the spark plugs, fix the float, check the timing.
You might also have broken a pushrod. Pull the valve cover and see if all the valves move when you crank it.
Paint & Body Shop moderator
