1 members (2-Ton),
167
Mod | | | Forums66 Topics128,088 Posts1,056,114 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#46235 06/13/2005 5:10 AM | Joined: Aug 2002 Posts: 117 Shop Shark | | Shop Shark Joined: Aug 2002 Posts: 117 | Hi...i have a 49 GMC,,,runs like a tractor,,my brother..moved it a little bit..Bang!!..blew muffler out..I tried to start it,,but she just won't pop..A freind of mine said,,probably cracked a Distributer..Does the GMC share the same kind of Distributer as the Chevy( i have some of those)...  | | |
#46236 06/13/2005 5:44 AM | Joined: Jan 2002 Posts: 622 Member | | Member Joined: Jan 2002 Posts: 622 | If it blew the muffler out, it backfired through the exhaust. This generally doesn't cause internal engine damage.
delete my account and pictures
#46237 06/13/2005 6:36 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Distributor's the same, but I'm thinking they have different vacuum advance.
Lots of things could be wrong. Start by checking the firing order. 153624. Then move to the points, spark plugs. It is possible to have a cracked distributor cap, but that usually won't keep one from starting.
Fred 52 3600 69 C-10
#46238 06/14/2005 9:50 AM | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | I'm thinking whatever made it backfire is why it won't start. I wonder if it might have gotten a load of gas in the exhaust manifold from a stuck float,and when it started,it ignited in the exhaust pipe and blew up the muffler. with a stuck float it might have drowned the plugs. | | |
#46239 06/14/2005 10:44 AM | Joined: Apr 2005 Posts: 641 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 641 | i just had to replage my float it was cracked skake and see you can get a new float for 10.00 | | |
#46240 06/16/2005 10:55 AM | Joined: Jun 2005 Posts: 221 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 221 | Start by checking firing order/ignition timing then check the distributor cap and rotor for cracks.Pull the spark plugs and see if they look wet if so you might have excess fuel going into the engine (flooding)i would check the timing/firing order first also check for proper point gap setting. | | |
#46241 06/16/2005 2:39 PM | Joined: May 2005 Posts: 33 Member | | Member Joined: May 2005 Posts: 33 | Check the coil. I've had this happen 4 or 5 times.(I'm just lucky I guess) One time I blew up a muffler on my '62 Impala. Man, sounded like a shotgun went off underneath me! It was the coil. Coil dies. Fuel loads up & then combusts. Put on new coil & starts up no problem. Good luck.
Life is good. Keep on playing.
#46242 06/17/2005 12:58 AM | Joined: Dec 2003 Posts: 299 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2003 Posts: 299 | Timing chain could have jumped a tooth, causing the misfire that blew out your muffler.now because of the cain being in the wrong tooth, your timing is out and it won't start. That's my guess. | | |
#46243 06/17/2005 1:56 AM | Joined: Sep 2003 Posts: 16 Junior Member | | Junior Member Joined: Sep 2003 Posts: 16 | :rolleyes: does a49 gmc have timeing chain??? | | |
#46244 06/17/2005 7:39 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | No timing chain in a Jimmy.
Replace the spark plugs, fix the float, check the timing.
You might also have broken a pushrod. Pull the valve cover and see if all the valves move when you crank it.
