0 members (),
86
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,151 Posts1,056,999 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2008 Posts: 18 New Guy | | New Guy Joined: Aug 2008 Posts: 18 | Does anyone have any idea where I can find it.I've looked on the doors,cowling,all the way around the doors.Under the dash the firewall is there any where left?The # on the title isDEA136864 if that helps. | | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | factory would have been on the passenger side of the cowl under the hood. if you have clutchhead screws holding nothing or empty holes in a rectangular pattern the plate has proably been (re)moved. When you open passenger side of hood the plates should be between windlace and front of firewall on the side of the cowl. did you run the serial number you have thru the vin cruncher to see if it is accurate to that model year? Also some states used the engine number for titling purposes. look on passenger side of engine below distributor and towards the rear of engine
| | | | | Joined: May 2008 Posts: 142 Wrench Fetcher | | Wrench Fetcher Joined: May 2008 Posts: 142 | DEA136864 refers to the orig engine stamped number. Consider yourself lucky, if you still have the orig engine. As kb3csw said, look at the flat flange aft of the distributor. You may need to use a wire brush to clean it up in order to see the stamped numbers. The prefix "DEA" is specific to the "1946" 2nd Design 235 motor. Your block cast number should be 839751. Please also reference Brads41-46chevys.com. Sounds as if your data plate is gone. | | |
