4 members (EchoBravoSierra, carbking, 2 invisible), 77 guests, and 2 robots.
Topics128,206
Posts1,057,438
Members48,471
Apprentice
Apprentice
These are on the rear. I was wondering why it sat lower on the driver side. Now I know. The 8.25's are mounted on the driver side and the 9.0's are on the passenger side. The last owner only ever used it to drag his horse arena and farm work, so it was in the dirt most of the time. Would this have hurt anything though? Are the rearends open or are they limited slip on the Big Bolts? Looks like I definitely need tires before I drive it on the street now.
1955 Chevy Dumptruck
2003 Chevy 2500HD: Crewcab, Longbed, 2wd, 6-speed manual
2005 Pontiac GTO: 500hp and a transbraked TH400
What size are the fronts? I just thought you might have 4 matching ones for the rear, and have the other pair in the front.
David Colter
pics * 1954 wrecker * [color:#009900]1948 Chevy 1-Ton[/color]
Unless it's spent a lot of miles on hard pavement at highway speed, there's probably no wear or damage to the spider gears. I don't think any of the older big rear ends had any sort of limited-slip arrangement available.
Maybe he drove it in a lot of crosswinds grin My '36 came with 5 different sizes out of 6 possible. Necessity is the mother of invention.
my 38 had 3 different sizes, the 54 only had 2 sizes
Apprentice
Apprentice
It's has 8.25-20 in front. The only thing I can think of is to put the two 9.0-20's in front, but I'm not sure they will fit. If it does work that would give me 9.0's in front and 8.25's in back.
you will have to watch your turn radius so you don't hit springs with tires on the front
