5 members (klhansen, Tronman, Otto Skorzeny, electors, 3B), 57 guests, and 2 robots.
Topics128,041
Posts1,055,489
Members48,424
#46156 06/10/2005 6:33 AM
Junior Member
Junior Member
I have a 1949 6400 with no wiring at all. I am trying to somehow get the engine to start. Any ideas on what to do? Any tips would be helpful. Thanks!!
Mike Richey
Big 49
#46157 06/10/2005 6:58 AM
First get a shop manual. Then look at the wiring schematic. But since you don't have that let me see if I can give you some basics. Battery to starter. Battery to ground (frame). Frame to engine. Starter to ingnition switch. Ingnition switch to coil (this one I am not too sure about _ refer to wiring diagram). I believe this is enought to get you started and running off the battery. Good luck!
Brian Moore
1949 3100 5 window Deluxe
"Today is better than yesterday, but not as good as tomorrow"
#46158 06/10/2005 9:42 PM
Riding in the Passing Lane
I take it has a floor starter. Run battery cables to ground & top of starter. Run a wire with a spring clip from the top of starter to + on coil. Run a wire from - coil to dist. If it gets fuel it should start. This is for testing purposes. You will need to buy or build a harness to get all systems working. smile
1972 Chevy c10 Cheyenne Super
