0 members (),
132
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#46156 06/10/2005 6:33 AM | Joined: Mar 2005 Posts: 9 Junior Member | | Junior Member Joined: Mar 2005 Posts: 9 | I have a 1949 6400 with no wiring at all. I am trying to somehow get the engine to start. Any ideas on what to do? Any tips would be helpful. Thanks!!
Mike Richey Big 49
#46157 06/10/2005 6:58 AM | Joined: Feb 2000 Posts: 985 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 985 | First get a shop manual. Then look at the wiring schematic. But since you don't have that let me see if I can give you some basics. Battery to starter. Battery to ground (frame). Frame to engine. Starter to ingnition switch. Ingnition switch to coil (this one I am not too sure about _ refer to wiring diagram). I believe this is enought to get you started and running off the battery. Good luck!
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | |
#46158 06/10/2005 9:42 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I take it has a floor starter. Run battery cables to ground & top of starter. Run a wire with a spring clip from the top of starter to + on coil. Run a wire from - coil to dist. If it gets fuel it should start. This is for testing purposes. You will need to buy or build a harness to get all systems working.  They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
