1 members (Hotrod Lincoln),
41
0
Mod | | | Forums66 Topics128,035 Posts1,055,560 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 33 Apprentice | | Apprentice Joined: Nov 2006 Posts: 33 | I have a 1946 Chevy 1/2 ton (getting close to rolling!).. I got the dash back in but can't figure out how the cowl vent lever connects. There is a piece of metal coming from the vent with a slot in the center and a tab on the end. There is also a similar piece (slot & tab) on the lever assembly. How do the two hook together?
Experience is the ability to recognize a mistake when you make it again....
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | On my 38 both parts have washboard surfaces on one side. Those go together washboard to washboard. Put a small bolt or machine screw through the slot with a washer & nut. Adjust to where the vent is fully closed when the lever is in the closed position & tighten the nut.
| | | | | Joined: Nov 2006 Posts: 33 Apprentice | | Apprentice Joined: Nov 2006 Posts: 33 | Thanks! Nice Car. I saw one just like it done by Jeff Campbell in Elgin Texas.. It had a 350 which barely fit.. Must be nice!
