Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
5 members (dt235sd, J Lucas, Hotrod Lincoln, Rich'sToys, 1 invisible), 113 guests, and 6 robots.
Topics128,290
Posts1,058,559
Members48,492
#458869 10/06/2008 1:46 PM
I am going to change the gear oil in my SM 420 and wanted to see if you guys know how much they hold and what weight oil to use.
Treyz,
The spec sheet says 6 pints of 90 weight. Today's call out would probably be 80w-90 which is more readily available and might work a little better.
I have included a link to a poop-sheet on your transmission. Good luck.
http://chevy.oldcarmanualproject.com/shop/1948_51truck/51ctsm0730.htm
Stuart
Thanks for the info Stuart. That is just what I needed...
