1 members (Rusty Heaps),
114
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2004 Posts: 103 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2004 Posts: 103 | Just returned from Hershey, PA with a repop speedo. I want to use my old face and install the new unit. I need to remove the needle to do so. Anyone had experience with this? Need particulars. I would like to advance the odometer to reflect the actual miles on the truck (60,000) and don't want to mess up the plastic mechanism. Any / all help is appreciated. Have not posted for some time due to restoration of LBC / Triumph Spitfire. Thanks for all replies. BW | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The needle just pulls off. Use gentle pressure, don't jerk on it.
To reset the odometer you need to disassemble the unit. Pay attention when you take it apart, there will be a test later. If you are mechanically inclined, go for it. | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Never took one off a repop, but I got the one of my original by taking a small screwdriver and gently rocking it back and forth until it came off. Putting it back on is nerve racking too... so I just drilled mine out so that it fit smoothly over the pin and used a little 5-minute epoxy to keep it on. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | OOOoooooo Woody. Hope you don't NEVER have to take it back off....
EDIT:...but then a new one is less than five bucks!!
| | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | OOOoooooo Woody. Hope you don't NEVER have to take it back off.... When I fixes something it stays fixed  | | |
