1 members (Hotrod Lincoln), 73 guests, and 1 robot.
Topics128,055
Posts1,055,782
#460839 10/12/2008 8:57 PM
I'm working on another truck. I have a (thick) grill that I wanna paint. If I sandblast it real good, will bondo and/or paint stick to it?
I don't know for sure about body filler, but you will most likely need to use a self etching primer before you paint to make sure it will stick.
Bill Burmeister
Remember sand blasting will warp the grille if you are not real careful! It will also leave pitting. Walnut hauls will leave a finer finish but again be careful of warpage on the light grille. Body Filler will stick to bare metal but if there is any dents it would be better to work them out carefully or if cracks they can be welded up and then worked out after grinding.
62Blue
Don
62Blue
62Chevy in progress
You've never been lost until you've been lost at Mach3" Paul F Crichmore (Test Pilot)
Don G. #460858 10/12/2008 11:01 PM
Last time I painted some chrome, it was new chrome!!!!!! I scored it with some fine sandpaper and epoxy primed it. No issues yet! But, boy it hurt to scratch it after I paid all that money to chrome it. ( It was a piece that required both chrome parts and painted parts.)
MNSmith #460912 10/13/2008 2:05 AM
John,
When I picked up my grille from the chrome guy, he told me to just be sure to scuff it up before I paint the stripe across the top. He said as long as I scuff it up good I should not have any problems with the paint sticking.
Tim Sheridan
1947 First Series Chevy 1/2-Ton
"Liberty Series" - "Art Deco" - Whatever you'd like to call it.
Sheridan #461005 10/13/2008 11:12 AM
Metal is metal and you can paint any metal. Like Bill and Tim posted, scuff your chrome as you would any other steel surface to prep it for painting and use a good bare metal primer or etching primer and there is no reason it shouldn't bond. Steel, nickel, chrome, i.e. the hard metals and don’t under normal conditions skin over very fast so you have a fairly large window when it comes to painting them. Cad plated, zinc or galvanized metals should be etched also before painting and you don't want to let them sit to long before applying a finish to them. Aluminum begins to oxidize or skin over as soon as you clean it so getting a primer on immediately after cleaning is imperative.
Denny G
Denny G
Sandwich, IL
Yes, it is just that simple... just be sure the surface is thoroughly scuffed before you paint. Paint does not molecularly bond to metal it adheres and those minute scratches is what makes the difference in how well it adheres.
You can paint a sheet of glass and it will stick and as long as you don't expose it to weather or abrasion... like painted signs on store windows. But trucks are exposed to all of the conditions that would deteriorate that bond.
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
Czechman #465247 10/27/2008 4:24 AM
I has OEM chrome front and rear Bumpers. I sanded with 80 grit primed with Napa Brand MS Self-etching Primer and rattled canned it with Rustoluem Plastic paint lloks absoulty great.. I posted a write up on it several month back.
1960 GMC 305A V-6 Gallery Page
Remember, the government cannot give --anything to anyone --that they have not first taken away from someone else.
BUY AMERICAN http://www.stillmadeinusa.com/index.html
