1 members (Hotrod Lincoln),
72
0
Mod | | | Forums66 Topics128,049 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 73 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 73 | i need a new water pump on my 261 in my c60. of course parts stores don't list 261s because they were only in big trucks. is the 235 pump identical? | | | | | Joined: Jun 2005 Posts: 388 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 388 | As can be seen from the Master Parts Manual , a 235 pump should fit a 261 from the same year etc. Is your 261 the early (54-55 first) or late version? I have used water pumps from 216s and 235s on 261s, all depending upon the pulley sizes desired, etc. | | | | | Joined: Mar 2008 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2008 Posts: 60 | The 261 water pump has a extra water outlet next to the heater outlet. This is a thermostat bypass that goes up to the thermostat housing . This lets water flow through the block when the thermostat is closed to stop hot spots in the engine. | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I've gotten water pumps labeled for 235's that were drilled and tapped for the extra outlet. You can add an outlet if you need to, its just a 1/2" NPT pipe thread.
