0 members (), 40 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#460689 10/12/2008 4:28 AM
i need a new water pump on my 261 in my c60. of course parts stores don't list 261s because they were only in big trucks. is the 235 pump identical?
bucket #460695 10/12/2008 4:42 AM
As can be seen from the Master Parts Manual , a 235 pump should fit a 261 from the same year etc. Is your 261 the early (54-55 first) or late version? I have used water pumps from 216s and 235s on 261s, all depending upon the pulley sizes desired, etc.
bucket #460899 10/13/2008 1:48 AM
2 Offline
The 261 water pump has a extra water outlet next to the heater outlet. This is a thermostat bypass that goes up to the thermostat housing . This lets water flow through the block when the thermostat is closed to stop hot spots in the engine.
28chevys #460976 10/13/2008 5:04 AM
I've gotten water pumps labeled for 235's that were drilled and tapped for the extra outlet. You can add an outlet if you need to, its just a 1/2" NPT pipe thread.
Paint & Body Shop moderator
